salmonrose Posted May 3, 2011 Posted May 3, 2011 (edited) Hi, I have an CAD file with a lot blocks which I don't use. I would like to delete them. So I do "Purge" which took care of some but not all. There are still a lot of "cannot purge" blocks. So I do "Insert", I see about 30 blocks. Choosing one of those, I can edit the block. (Doing the "Insert" was just my beginner's test step to see how many unwant blocks I still have.) I believe they cannot be purged because they are nested. How can I delete the 'cannot be purged" unused blocks? I know a lot of the blocks have other blocks nested in them. Is deleting the 'parent' blocks enough for me to purge? Thanks. PS: I only have limited knowledge with AutoCAD, so please be more specific of what to do. Edited May 3, 2011 by salmonrose Added info Quote
Grant Posted May 4, 2011 Posted May 4, 2011 If you have a block or nested block in the drawing then you will not be able to purge them. You will need to get rid of every instance of that block before you can purge it out. Quote
SLW210 Posted May 4, 2011 Posted May 4, 2011 Use _QSELECT and use the different options available to select the blocks and delete them. Purge is not a delete tool, it purges UNUSED block definitions, dimension styles, layers, linetypes, text styles, zero-length geometry and empty text objects. ALL references to a block must be erased before you can purge the block definition. P.S. Do any of the blocks have names that start with *? Quote
designerstuart Posted May 4, 2011 Posted May 4, 2011 Doing the "Insert" was just my beginner's test step to see how many unwant blocks I still havei do the same, but i use RENAME. this lists lots of objects in the drawing, which i find better than using the design center (Ctrl+2) as mentioned above, if you delete all the instances of a block, whether nested or not, you can purge their definitions and they will be gone forever. Quote
sleepy86 Posted October 16, 2014 Posted October 16, 2014 I have the same problem. It's terrible because the file size is big Quote
BIGAL Posted October 16, 2014 Posted October 16, 2014 Purge renaming etc will not work !!! Very simple with CIV3d run PURGESTYLES this will remove unused styles this in turn allows the purging of unused blocks that are linked to a style as well as layers linetypes etc. Styles lock their child components. To get a style back simplest way is IMPORTSTYLES. Did one today removed 330 styles then purged etc Quote
Ski_Me Posted October 16, 2014 Posted October 16, 2014 He may have blocks that were part of a xref those cannot be purged unless the xref is detached Quote
RobDraw Posted October 16, 2014 Posted October 16, 2014 He may have blocks that were part of a xref those cannot be purged unless the xref is detached This information is not correct. Blocks from an XREF do not get inserted to the referencing file. XREFs do not increase file size by any noticeable amount. Quote
jade1331 Posted December 19, 2014 Posted December 19, 2014 So i have tried many things to get rid of older blocks that where somehow imported into our template. I can see them I hit Ctrl+2, some of the ones I want to get rid of have names like "A$C51A644A3" I have tried the filter option and the _qselect. Filter allows me to select those blocks but after searching each of my layouts and model space I did not see them. _qselect does not give me an option to select these type of blocks by name. They are not listed in the drop down menu and if I manually enter the name it highlights every object. Do you have any suggestions... i just want to delete every instance of the object... if it happens to delete something with it that would be fine just as long as the blocks are gone. Thank you if you respond I know it was years ago when you posted your comment. Use _QSELECT and use the different options available to select the blocks and delete them. Purge is not a delete tool, it purges UNUSED block definitions, dimension styles, layers, linetypes, text styles, zero-length geometry and empty text objects. ALL references to a block must be erased before you can purge the block definition. P.S. Do any of the blocks have names that start with *? Quote
ReMark Posted December 20, 2014 Posted December 20, 2014 It could be that you have instances of anonymous blocks in your drawing. Please attach a copy of the drawing file to your next post. Someone here will take a look at it. If the file is too large then you'll have to use a file sharing website like Dropbox. Quote
Victery1 Posted May 12, 2015 Posted May 12, 2015 If your unpurgeable block names begin with *A, then try this... Sub deleteUnpurgableBlks() Dim blk As acadBlock Dim blks As AcadBlocks Set blks = ThisDrawing.Blocks For Each blk In blks If LEFT(UCase$(blk.name), 2) = "*A" Then blk.Delete End If Next End Sub Quote
CantCacheMe Posted May 15, 2015 Posted May 15, 2015 I had the same issue and ran across this fix. I did just what they said. I typed in -wblock, found a place and new name to save my drawing, typed *, opened the new drawing and all of my blocks were gone. I also had a lot of layers that were nested within the blocks that I had been trying to get rid of and they were all gone too. Hopefully, this will be helpful to you. I can't take credit for it if it works though. Quote
