kalai Posted May 4, 2011 Posted May 4, 2011 is it possible to connect to webserver database? i am able to connect to local host. help me. Quote
SOliver Posted May 4, 2011 Posted May 4, 2011 The process will be the same as connecting to localhost. Replace the "localhost" string with the IPv4 for the connection(might need the port number). Make sure the offsite hosted sql server allows remote connections. Quote
kalai Posted May 5, 2011 Author Posted May 5, 2011 thanks, Hi, In my project i need to connect webserver MySQL database without installing ODBC. It is possible? In my localhost it works correctly, my code for connecting localhost MySQL database as below (setq dbConnString (strcat "DRIVER={MySQL ODBC 5.1 Driver}; SERVER=localhost;" "DATABASE=localhostdb; UID=localhostusername; PWD=localhostpassword; OPTION=3" ) I try for webserver MySQL as below, but it displays error (setq dbConnString (strcat "DRIVER={MySQL ODBC 5.1 Driver}; SERVER=webserverhostname.com;" "DATABASE=dbname; UID=webserusername; PWD=webserverpassword; OPTION=3" ) error: ......Microsoft OLE DB Provider for ODBC Drivers: [MySQL][ODBC 5.1 Driver]Can't connect to MySQL server on 'webserverhostname.com' pls tell me , how to connect webserver MySQL database Quote
irneb Posted May 5, 2011 Posted May 5, 2011 There's one of 2 things which may be occurring: (1) the machine running your code could have a firewall which prevents connections on the default MySQL port number; or (2) the server doesn't allow direct remote access to the MySQL db. I think the later is what's happening as this is the default behaviour for MySQL, it's meant to run on a web server through a local PHP engine - so the data gets sent as html pages instead of direct db connections (it's more secure that way). You could set the MySQL server to allow remote access. But that's not going to fix your "other" problem. The connect string you're using requires the MySQL ODBC driver to be installed on the client PC. Unfortunately I don't know of a way to get around this. Perhaps some way of linking lisp to a web page instead, then design a PHP page to retrieve the data from the local MySQL server into html and send this to the client PC. But this is probably going to be quite an involved thing though. Quote
kalai Posted May 5, 2011 Author Posted May 5, 2011 pls tell me how to enable the remote connections in webserver Quote
irneb Posted May 5, 2011 Posted May 5, 2011 We'll need more info, when you say "webserver" what brand / make / OS / etc. There are numerous types and each have their own settings. But that's probably something you'd be able to get from that particular brand's forums (instead of here), or even the MySQL forums perhaps. Quote
