How do I purge linetypes from a dynamic block? I have hundreds of blocks that make up our legend items and I want to remove unwanted items to reduce the sizes of them.
Thanks
Purge is not a delete tool, it purges UNUSED block definitions, dimension styles, layers, linetypes, text styles, zero-length geometry and empty text objects.
ALL references to a linetype must be erased before you can purge the linetype.
  • 9 years later...
Just insert the block into a blank drawing. Make sure no other unwanted in it, ie styles, linetypes, layers, etc. After insert the dynamic block, PURGE all and wblock it out.
