yajis_narif Posted May 4, 2011 Posted May 4, 2011 hiii it's me again i just have another problem i have created an array of circles then i used insert to get 4 blocks (array of circles ) in my drawing... now i want to get the center of each circle in each block (setq y (entget (cdr( assoc -2 (tblsearch "block" "AC" ))))) (setq lis (length y)) (setq m 0) (repeat lis (setq w (car (nth m y))) (if (= w 10) (progn (setq center (cdr (nth m y))) )) (setq m (1+ m)) ) this code gives me the center of the reference circle i want to have the center of all circles Quote
Tharwat Posted May 4, 2011 Posted May 4, 2011 Is this what you mean ? (defun c:test (/ ss) (if (and (entget (cdr (assoc -2 (tblsearch "block" "AC")))) (setq ss (ssget '((0 . "CIRCLE")))) ) ((lambda (i / sset e) (while (setq sset (ssname ss (setq i (1+ i)))) (setq e (entget sset)) (command "_.-insert" "AC" (cdr (assoc 10 e)) "" "" "") ) ) -1 ) (princ) ) (princ) ) TharwaT Quote
yajis_narif Posted May 4, 2011 Author Posted May 4, 2011 Is this what you mean ? (defun c:test (/ ss) (if (and (entget (cdr (assoc -2 (tblsearch "block" "AC")))) (setq ss (ssget '((0 . "CIRCLE")))) ) ((lambda (i / sset e) (while (setq sset (ssname ss (setq i (1+ i)))) (setq e (entget sset)) (command "_.-insert" "AC" (cdr (assoc 10 e)) "" "" "") ) ) -1 ) (princ) ) (princ) ) TharwaT your code asks me to select objects but my current drawing is 4 insert of the same block and my block is an array of circles so i want the center point of each circle in the block Quote
Tharwat Posted May 4, 2011 Posted May 4, 2011 So you have a block consist of four circles and you want to get the center point of each circle ? Quote
yajis_narif Posted May 4, 2011 Author Posted May 4, 2011 So you have a block consist of four circles and you want to get the center point of each circle ? yes i want the center point of each circle when i use the tblsearch and the entget (assoc 10 ) it gives me the center of the reference circle of the array drawing.dwg Quote
Lee Mac Posted May 4, 2011 Posted May 4, 2011 Try something like this: (defun c:test ( / e mv ) (vl-load-com) (if (and (setq e (LM:Select "\nSelect Block: " (function (lambda ( x ) (eq "INSERT" (cdr (assoc 0 (entget x))))) ) entsel ) ) (setq mv (LM:Def->Ref (vlax-ename->vla-object e))) ) ( (lambda ( ent ) (while (setq ent (entnext ent)) (if (eq "CIRCLE" (cdr (assoc 0 (entget ent)))) (entmakex (list (cons 0 "POINT") (cons 10 (mapcar '+ (mxv (car mv) (cdr (assoc 10 (entget ent)))) (cadr mv))) (assoc 210 (entget e)) ) ) ) ) ) (tblobjname "BLOCK" (cdr (assoc 2 (entget e)))) ) ) (princ) ) ;;---------------=={ Block Def -> Block Ref }==---------------;; ;; ;; ;; Returns the Transformation Matrix and Translation Vector ;; ;; for transforming Block Definition Geometry to a Block ;; ;; Reference. ;; ;;------------------------------------------------------------;; ;; Author: Lee Mac, Copyright © 2011 - www.lee-mac.com ;; ;;------------------------------------------------------------;; ;; Arguments: ;; ;; SourceBlock - VLA Block Reference Object ;; ;;------------------------------------------------------------;; ;; Returns: List of 3x3 Transformation Matrix, Vector ;; ;;------------------------------------------------------------;; (defun LM:Def->Ref ( SourceBlock / norm ang x y z ) (setq norm (vlax-get SourceBlock 'Normal) ang (vla-get-rotation SourceBlock)) (mapcar (function (lambda ( sym prop alt ) (set sym (vlax-get-property SourceBlock (if (vlax-property-available-p SourceBlock prop) prop alt) ) ) ) ) '(x y z ) '(XEffectiveScaleFactor YEffectiveScaleFactor ZEffectiveScaleFactor) '(XScaleFactor YScaleFactor ZScaleFactor ) ) ( (lambda ( m ) (list m (mapcar '- (vlax-get SourceBlock 'InsertionPoint) (mxv m (cdr (assoc 10 (tblsearch "BLOCK" (vla-get-name SourceBlock)))) ) ) ) ) (mxm (mapcar (function (lambda ( e ) (trans e 0 norm t)) ) '((1. 0. 0.) (0. 1. 0.) (0. 0. 1.)) ) (mxm (list (list (cos ang) (sin (- ang)) 0.) (list (sin ang) (cos ang) 0.) (list 0. 0. 1.) ) (list (list x 0. 0.) (list 0. y 0.) (list 0. 0. z) ) ) ) ) ) ;; Matrix Transpose - Doug Wilson ;; Args: m - nxn matrix (defun trp ( m ) (apply 'mapcar (cons 'list m)) ) ;; Matrix x Matrix - Vladimir Nesterovsky ;; Args: m,n - nxn matrices (defun mxm ( m n ) ( (lambda ( a ) (mapcar '(lambda ( r ) (mxv a r)) m)) (trp n)) ) ;; Matrix x Vector - Vladimir Nesterovsky ;; Args: m - nxn matrix, v - vector in R^n (defun mxv ( m v ) (mapcar '(lambda ( r ) (apply '+ (mapcar '* r v))) m) ) ;;---------------------=={ Select if }==----------------------;; ;; ;; ;; Continuous selection prompts until a predicate function ;; ;; is validated ;; ;;------------------------------------------------------------;; ;; Author: Lee Mac, Copyright © 2011 - www.lee-mac.com ;; ;;------------------------------------------------------------;; ;; Arguments: ;; ;; msg - prompt string ;; ;; pred - optional predicate function taking ename argument ;; ;; func - selection function to invoke ;; ;;------------------------------------------------------------;; ;; Returns: selected entity ename if successful, else nil ;; ;;------------------------------------------------------------;; (defun LM:Select ( msg pred func / e ) (setq pred (eval pred)) (while (progn (setvar 'ERRNO 0) (setq e (car (func msg))) (cond ( (= 7 (getvar 'ERRNO)) (princ "\n** Missed, Try again **") ) ( (eq 'ENAME (type e)) (if (and pred (not (pred e))) (princ "\n** Invalid Object Selected **") ) ) ) ) ) e ) Quote
yajis_narif Posted May 4, 2011 Author Posted May 4, 2011 thank you lee mac your programe is perfect it shows the center of each circle but one more thing can i get a list of the coordinate of each circle ?? Quote
Lee Mac Posted May 4, 2011 Posted May 4, 2011 one more thing can i get a list of the coordinate of each circle ?? Yes, create a list using the point supplied to the entmake expression when creating the Point Entity. Quote
yajis_narif Posted May 4, 2011 Author Posted May 4, 2011 ok thank you so much Lee Mac i will try Quote
yajis_narif Posted May 4, 2011 Author Posted May 4, 2011 ok i will thanks right now i'm stuck in understanding the code it's kinda hard for me because i'm just a beginner in autolisp so i have no idea about all the V function in there Quote
