Quoted from the dotsoft website re: what are proxies?
"They are custom objects that require the presence of the application that generated them to be 'fully' functional."
Visit AutoDesk and download one of their free Object Enablers to help you out with your problem.
i downloaded all the needed object enablers from the autodesk, still having problems... i have dwg and pdf files, and i can see that many lines are missing in dwg...:S
AutoCAD 2007. You tried an insertion and received the dreaded Proxie Information window. One of the missing applications is Hypersteel. Were there any others? If so, which ones? Where did you get the drawing you're taking these objects from?
