dlxowhd Posted May 5, 2011 Posted May 5, 2011 when i go to insert -> attach, then the attach file manager window/panel should pop up and in there, i can select file and scale and all that stuff, right? but now, i haven't changed anything but when i click attach, it just says 'path to file to attach'. then i gotta type the whole path of the file manually. it's super annoying and i don't know why it's doing this all of a sudden. i'm using autocad 2011. please help me fix this problem. Quote
dlxowhd Posted May 6, 2011 Author Posted May 6, 2011 thanks it worked but do you have any idea why it happened?? i didn't change any settings and boom! it was like that all of sudden. maybe i hit some kind of a shortcut key by accident? Quote
SLW210 Posted May 6, 2011 Posted May 6, 2011 Do you run any LISP (including Express Tools) or third party add-ons? Quote
dlxowhd Posted May 6, 2011 Author Posted May 6, 2011 no i don't. but it was a big file i was working on and my pc couldn't handle it very well.. it was chugging along.. lagging quite a bit.. maybe that's got something to do with it.. i don't know.. Quote
Murph_map Posted May 7, 2011 Posted May 7, 2011 Cancelling out of some commands may also cause it to reset. Quote
Eurodude Posted May 9, 2011 Posted May 9, 2011 The other one you may also have to reset is "CMDDIA" Quote
