ctt Posted May 6, 2011 Posted May 6, 2011 Hi guys, Is this possible in any way? I need to hatch an area over an x-refed image and needs to be in colour and transparent. Thanks Quote
SLW210 Posted May 6, 2011 Posted May 6, 2011 AutoCAD 2011 has transparency for hatches, I am pretty sure AutoCAD 2010 does as well. Do you not have transparency at lower right of Hatch editor? Send the image the the back and the hatch to the front. Quote
ctt Posted May 8, 2011 Author Posted May 8, 2011 Yeah i know 2011 does but i was hoping 2010 did to. No, nothing there. Quote
ccowgill Posted May 10, 2011 Posted May 10, 2011 what we did prior to 2011 was to use a dot hatch, that would give the illusion of being transparent. Quote
Murph_map Posted May 10, 2011 Posted May 10, 2011 what we did prior to 2011 was to use a dot hatch, that would give the illusion of being transparent. Or use AutoCAD MAP3D and FDO. Quote
designerstuart Posted May 10, 2011 Posted May 10, 2011 yes coloured dots do the trick for those of us way back in 2009! spacing is your way to control transparency. Quote
