enemigoman Posted April 25, 2006 Posted April 25, 2006 How do I export the XYZ coordinate data of 3D polyline vertices into a *txt or *xls files? Quote
fuccaro Posted April 25, 2006 Posted April 25, 2006 You will need a Lisp routine. Do you have the full AutoCAD? Quote
enemigoman Posted April 25, 2006 Author Posted April 25, 2006 Yes, I do have the full of AutoCAD 2007. Do you know where I can find such a routine? Thanks for the reply Quote
rkmcswain Posted April 25, 2006 Posted April 25, 2006 Try PTEXPORT.LSP, found at http://www.dotsoft.com/freestuff.htm Quote
Joro-- Posted April 25, 2006 Posted April 25, 2006 You can try the following VBA application. It displays the coordinates of all 3DPolylines selected by the user in Excel. Sub Export3DPolylines() Dim objSS As AcadSelectionSet On Error Resume Next ThisDrawing.SelectionSets("MySS").Delete ThisDrawing.SelectionSets.Add ("MySS") Set objSS = ThisDrawing.SelectionSets("MySS") objSS.SelectOnScreen Dim objent As AcadEntity Dim MasRem() As AcadEntity Dim N As Integer N = -1 For Each objent In objSS If objent.ObjectName "AcDb3dPolyline" Then N = N + 1 If N = 0 Then ReDim MasRem(N) Else ReDim Preserve MasRem(N) End If Set MasRem(N) = objent End If Next objSS.RemoveItems MasRem If objSS.Count = 0 Then MsgBox "No 3DPolylines found!" Exit Sub End If Dim Excel As Object Set Excel = CreateObject("Excel.Application") Set wkb = Excel.workbooks.Add Set sht = wkb.sheets(1) Dim MasCoord As Variant Dim Col As Integer Dim Row As Integer Col = -3 Row = 1 For i = 0 To objSS.Count - 1 Col = Col + 4 Row = 1 MasCoord = objSS(i).Coordinates sht.cells(1, Col) = "3DPolyline " & i + 1 & " coordinates" sht.cells(2, Col) = "X" sht.cells(2, Col + 1) = "Y" sht.cells(2, Col + 2) = "Z" Row = 2 For j = 0 To (UBound(MasCoord) + 1) / 3 - 1 Row = Row + 1 sht.cells(Row, Col) = MasCoord(3 * j) sht.cells(Row, Col + 1) = MasCoord(3 * j + 1) sht.cells(Row, Col + 2) = MasCoord(3 * j + 2) Next Next Excel.Visible = True End Sub Quote
fuccaro Posted April 26, 2006 Posted April 26, 2006 and this is for exporting polyline points into text or csv files to open them in excel. Note thet you can edit the program text tochange the separator. You may use \t to have the items separated by a tab, \n to have them on a new line or use any other symbol. ;export old style polyline vertex coords to a text file ; [email="mfuccaro@hotmail.com"]mfuccaro@hotmail.com[/email] (defun c:pl2tx( / en ask i a file) (while (not ask) (setq en (car (entsel))) (if en (setq ask (= "POLYLINE" (cdr (assoc 0 (entget en)))))) ) (setq file (open (getfiled "Output file" (strcat (getvar "dwgprefix") (substr (getvar "DWGNAME") 1 (- (strlen (getvar "dwgname")) 4))) "txt" ;file type 1) "w")) (setq i 0 sep ";") ;sep=separator (while (or (zerop i) a) (setq a (mapcar 'rtos (cdr (assoc 10 (entget (setq en (entnext en))))))) (if a (write-line (strcat (car a) sep (cadr a) sep (caddr a)) file)) (setq i (1+ i)) ) (close file) (princ (strcat "\n" (itoa (1- i)) " points exported")) (princ) ) And HERE you will find help on how to run Lisp routines. Quote
kdesrosiers Posted April 15, 2010 Posted April 15, 2010 Hey... a few years later I found this post. I ran the vba from Joro thanks it works really good except that... Id really like to have alle the coordinate in the first 3 row. The code does export the coordinate of each polyline in different set of 3 row. I tried to modified the code with no sucess. I tried to change col = col +4 to col = col but it didnt work. I no nothing about coding. If someonw can help it will save me a lot of time. Thanks Quote
sudam Posted March 20, 2019 Posted March 20, 2019 Hello, Any one can help me. i am working a small company. client need to export data from autocad 2016 ( Sl NO, X ,Y, X ,ID) in CSV or EXcel. some one please help me. Thank you. Quote
BIGAL Posted March 21, 2019 Posted March 21, 2019 Did you read the posts all the answers are there. Also a Autocad point does not have ( Sl NO, X ,Y, X ,ID) the ID in particular. Are you talking abouting CIV3D very different answers. Quote
BCConnor Posted May 17, 2019 Posted May 17, 2019 Good Afternoon, With the help from "HowToAutoCAD.com" I was able to modify the script below. The script works fine, but when the points gets exported to CSV they are written in random order. I would like to have the points listed in numerical order from lowest to highest. My understanding is that I first need to use an array to list the points and then sort the points and then export the points out to CSV. But, I really do not know setup an array and then sort the points. Is it possible for someone to help me with this? Option Explicit Sub ExportPoints() Dim currentSelectionSet As AcadSelectionSet Dim ent As AcadEntity Dim pnt As AeccPoint Dim csvFile As String Dim FSO As FileSystemObject Dim textFile As TextStream Set currentSelectionSet = Thisdrawing.ActiveSelectionSet If currentSelectionSet.Count = 0 Then Thisdrawing.Utility.Prompt "There are no currently selected objects. Please select some points to export, and run this command again." & vbNewLine End If csvFile = csvFile & "POINT NO." & "," & "EASTING" & "," & "NORTHING" & "," & "ELEVATION" & "," & "FEATURE CODE" & vbNewLine For Each ent In currentSelectionSet If TypeOf ent Is AeccPoint Then Set pnt = ent csvFile = csvFile & pnt.Number & "," & Round(pnt.Easting, 3) & "," & Round(pnt.Northing, 3) & "," & Round(pnt.Elevation, 3) & "," & pnt.Description & vbNewLine End If Next Set FSO = New FileSystemObject Set textFile = FSO.CreateTextFile((Left(Thisdrawing.Name, Len(Thisdrawing.Name) - 4)) & ".csv") textFile.Write csvFile textFile.Close Thisdrawing.Utility.Prompt "Points were exported to the same folder as this drawing." & vbNewLine End Sub Quote
