elliecup Posted May 6, 2011 Posted May 6, 2011 I have imported a DXF file from mapinfo into autocad, these seed points contain x,y values but also if you list properties they also contain other information in this came names. I need these names to appear beside the point in autocad for printin purposes ....help !!! There are 1619 points and hand tying would be a huge task. Ellie Quote
CyberAngel Posted May 6, 2011 Posted May 6, 2011 By "properties" and "information" and "names" I'm guessing you mean the description for each point. Typically that's what you get from surveyors. I'm not sure how you would do that in Map 3D. In Civil 3D you can edit a point style to show or hide the data, and then apply the style to the points. Quote
Murph_map Posted May 7, 2011 Posted May 7, 2011 With Map3D you can do a text query or use annotation blocks. Quote
Tyke Posted May 7, 2011 Posted May 7, 2011 ellicup, can you post some more specific information and perhaps a couple of screen shots. Where exactly can you see this information? Quote
