Jest Posted May 6, 2011 Posted May 6, 2011 The first time I started Acad Map 3D 2012, I choose "2D drafting Workspace". Then I made some changages and saved It with different name. (e.g. "My Work"). I set it as current. But every time I close and reopen Acad, workspace is automatic switched back to "2D drafting Workspace", even if I set "My Work" as default and current in Customize user interface... I never met this problem before in previous versions. Can anybody help me to solve this bug? Jest Quote
SLW210 Posted May 6, 2011 Posted May 6, 2011 _WSSETTINGS select "Automatically save workspace changes" under When switching Workspaces You may need to set up a template file, I do not use 2012 so this may be a bug. Quote
Jest Posted May 6, 2011 Author Posted May 6, 2011 I thnik I've found the solution. I simly renamed "2d drafting Workspace" (added few characters in the begining..) It's working now..... so far. I hope it wont cause any other troubles in the future.. Quote
