raj Posted May 6, 2011 Posted May 6, 2011 i have drawn a line of 10 units when i use dimlinear i get he measure of 10 i want to add a prefix to the dimension for example || i need || ! ! ! ! can some one help me out with this and i need it in normal autolisp routine as i dont use ads Quote
raj Posted May 6, 2011 Author Posted May 6, 2011 i checked it with dimpost but its adding a suffix to it instead of a prefix Quote
jaylo23 Posted May 6, 2011 Posted May 6, 2011 Bring up your dimension dialogue box, select the dim style you are using or create a new one, hit the modify button, and under the "primary units tab" there is a section called prefix and suffix. Add "pcd" in the prefix section. Quote
raj Posted May 6, 2011 Author Posted May 6, 2011 @ SLW210 thanks mate u solved my problem and thank u jaylo23 Quote
