hdg2318 Posted May 8, 2011 Posted May 8, 2011 i have library, i created mns file for private menu bar, and i want to add private to right click menu. anybody help me, plz! Thanks so much ! Quote
Ahankhah Posted May 8, 2011 Posted May 8, 2011 If you are using AutoCAD 2011, it uses cuix files as menus, and not mnu, mns or cui. Anyway, 1- Issue "CUI" command. 2- In the dialog, search in the left pane and find "Shortcut Menus" item. All the right click menus are defined here. If you add any option to "Command Menu", it will display inside all commands containing options (i.e. in LINE command when you have choices of Undo or Close). To add your desired options to right click menu when there is no command active, insert it into "Default Menu". To add option to shift-right click menu, add it to "Object Snap Cursor Menu". Quote
hdg2318 Posted May 8, 2011 Author Posted May 8, 2011 thanks for your reply! i known that, but i have so many PC, each PC use other Autocad version, so i cant use only cui or cuix file for all version. I want use mns file because all version support that kind. I mean, when i load private menu by command MENULOAD, right click menu also loaded. But i dont know how to do that. Do you know? Quote
Ahankhah Posted May 8, 2011 Posted May 8, 2011 I checked AutoCAD 2005 acad.mnu. If you want to add your desired item and command to right click menus, you must insert it to: ***POP501 (**CMDEFAULT) and ***POP503 (**CMCOMMAND) ***POP501 **CMDEFAULT [[b]Context menu for default mode[/b]] ID_CMNonLast [&Repeat %s]^C^C; [--] ID_Cutclip [Cu&t]^C^C_cutclip ID_Copyclip [&Copy]^C^C_copyclip ID_Copybase [Copy with &Base Point]^C^C_copybase ID_Pasteclip [&Paste]^C^C_pasteclip ID_Pastebloc [Paste as Bloc&k]^C^C_pasteblock ID_Pasteorig [Paste to Original Coor&dinates]^C^C_pasteorig [--] ID_U [&Undo]^C^C_u ID_Redo [Re&do]^C^C_mredo 1 ID_Pan [P&an]'_pan ID_ZoomRealt [&Zoom]'_zoom ; [--] ID_Filter [&Quick Select...]^C^C_qselect ID_TextFind [&Find...]^C^C_find ID_Preferenc [&Options...]^C^C_options ***POP503 **CMCOMMAND [[b]Context menu for command mode[/b]] ID_Enter [&Enter]; ID_Cancel [&Cancel]^C [--] ID_SubSnaps [->Snap O&verrides] ID_Tracking [Temporary trac&k point]_tt ID_From [&From]_from ID_MidTwoPts [Mid Bet&ween 2 Points]_m2p ID_MnPointFi [->Poin&t Filters] ID_PointFilx [.X].X ID_PointFily [.Y].Y ID_PointFilz [.Z].Z [--] ID_PointFixy [.XY].XY ID_PointFixz [.XZ].XZ ID_PointFiyz [<-.YZ].YZ [--] ID_OsnapEndp [&Endpoint]_endp ID_OsnapMidp [&Midpoint]_mid ID_OsnapInte [&Intersection]_int ID_OsnapAppa [&Apparent Intersect]_appint ID_OsnapExte [E&xtension]_ext [--] ID_OsnapCent [&Center]_cen ID_OsnapQuad [&Quadrant]_qua ID_OsnapTang [Tan&gent]_tan [--] ID_OsnapPerp [&Perpendicular]_per ID_OsnapPara [Para&llel]_par ID_OsnapNode [No&de]_nod ID_OsnapInse [in&sert]_ins ID_OsnapNear [Nea&rest]_nea ID_OsnapNone [&None]_non [--] ID_Osnap [<-&Osnap Settings...]'_+dsettings 2 [--] ID_Pan [$(if,$(eq,$(substr,$(getvar,cmdnames),1,4),ZOOM),~,)&Pan]'_pan ID_ZoomRealt [$(if,$(eq,$(substr,$(getvar,cmdnames),1,4),ZOOM),~,)&Zoom]'_zoom ; Quote
hdg2318 Posted May 9, 2011 Author Posted May 9, 2011 it mean, i must insert my menu code into both ***POP501 and ***POP503 ? as the code you posted, POP501 likely the menu default right click, but POP503 is use for menu when use command relate osnap point. that right? I also found in mnu file of previous version cad ( 2004, 2005) and i see that have menugroup in code: ***MENUGROUP=ACAD ***BUTTONS1 $M=$(if,$(eq,$(substr,$(getvar,cmdnames),1,5),GRIP_),$P0=ACAD.GRIPS $P0=*); $P0=SNAP $p0=* ^C^C ... ***POP0 **SNAP [&Object Snap Cursor Menu] ID_Tracking [Temporary trac&k point]_tt ID_From [&From]_from ID_MnPointFi [->Poin&t Filters] ID_PointFilx [.X].X ID_PointFily [.Y].Y ID_PointFilz [.Z].Z and my menu code ***MENUGROUP=PRIVATE ***POP11 **STANDARD ... does the menu for right click have to insert to MENUGROUP ACAD or not? Quote
Ahankhah Posted May 10, 2011 Posted May 10, 2011 ... POP503 is use for menu when use command relate osnap point. that right? Not correct. ***POP503 (**CMCommand) popups when you are inside a command with options (i.e LINE, when you specified at least one point.) Quote
Ahankhah Posted May 10, 2011 Posted May 10, 2011 does the menu for right click have to insert to MENUGROUP ACAD or not? You can load several menus into AutoCAD, so I offer you to make your own menu and save it in AutoCAD support folder (the folder in it ACAD.MNU exists). When in AutoCAD, issue "MENULOAD" command and load the menu. Of course, the method doesn't work for POP 500+ popup menus, so you must change those in ACAD menugroup. Quote
hdg2318 Posted May 13, 2011 Author Posted May 13, 2011 thanks so much, i will try and test again. Quote
