Double click to zoom e
I'm using Acad 2004 at home
My double click is way too sensitive. when I carefully scroll in, I suddenly zoom e. Sometime it takes me 3 tries before I can scroll in
Sounds like a mouse related problem. What mouse are you using? When did the problem first occur? Had you made any recent changes to your system (hardware/software)? Did you check Device Manager? Did you install any software specific to the mouse like Intellimouse?
It's a brand new microsoft mouse. I haven't made any changes to the system
I'll try changing mice
Before changing the mouse I would check the mouse properties. There's got to be a setting that can be adjusted to make it work the way you want.
Click on Start > Control Panel > Printers and Other Hardware > Mouse. The Mouse Properties pop-up window should appear. There should be four or five tabs to choose from including Buttons and Wheels. Check it out.
Did any software come with your new mouse?
