Hey guys,
I have an assembly where i have produced a hooked type tube for a handle, what i want to do is enter both of these into the asm and then remove one from the other leaving me with two correspond parts.
How can i do this in inventor?
Thanks.
basically using the boolean technique
Edit in the context of the assembly and Copy Object as surface body for Split or Sculpt.
Attach your assembly here if you can't figure it out.
