M76 Posted May 10, 2011 Posted May 10, 2011 Hi I'd like to create a macro that would be used in parallel with the main autocad window, but when I run the macro it deactivates all other autocad windows, and the drawing can only be used after I close the form of the macro. But I don't want to close it I want to keep it open while I work on the drawing. How can I achieve this? Thanks. Quote
SEANT Posted May 10, 2011 Posted May 10, 2011 See modal versus modeless forms http://msdn.microsoft.com/en-us/library/aa984358(v=vs.71).aspx Quote
M76 Posted May 10, 2011 Author Posted May 10, 2011 Thanks, I know this all well, I was asking how can I control if a form is modal in the autocad macro? But I've found the solution, the show method has a boolean parameter which determines if the form is shown as modal or not. Quote
