tds73 Posted May 10, 2011 Posted May 10, 2011 ok I will start by saying I am by no means good with autocad, but I fumble thru most of it. I tried a search for what I am looking for and did not come up with an answer, if someone knows of a post to help me, please let me know and I will go thru it and not waste anyones time. So, what I am attempting to do is: add text, some dims., and some info. to a viewport i have added to a drawing for my field guys. I am a sheet metal worker and have produced a drawing of duct work. one viewport is a plan view, one is a swiso, and another is a left-elevation view. everything is good except the left-elevation view which I would like to add details to. I am assuming I need to change the ucs so that i can place lines, dims and text and get them to show up without them snapping to 0 z. i just can't figure out how/steps to get this to work easily for me. please help. Quote
ReMark Posted May 10, 2011 Posted May 10, 2011 Where are you placing your dimensions? In model space or in your paper space layout? Quote
tds73 Posted May 10, 2011 Author Posted May 10, 2011 in paper space, since the view is like i want it without having to turn off layers etc. the plan view viewport is the main one. does that make sense to you? it is possible i am not doing it "the correct" way, just easiest in my mind for me. Quote
ReMark Posted May 10, 2011 Posted May 10, 2011 I'm working on a drawing right now of a tank platform with multiple views (top, front, side and iso) of many of the pieces. I do all my dimensioning in my layout. I am not experiencing any problem dimensioning or labeling any particular view. I have not ever had to reorient the UCS in a layout either. Did you change your UCS for some reason? What kinds of details do you want to add to the left-elevation view? Quote
tds73 Posted May 10, 2011 Author Posted May 10, 2011 i basically just need to add some notes to the one view so i can print the drawing, then i will basically delete that view port since i will not need it for the next drawing i print. i break up my install drawings into systems, supply and return, one drawing for each. i try to put as much info relating to a sytem on a drawing as i can for the field guys. i turn off or delete any info that does not relate to that system when printing the drawing to try and take out any confusion, and make it as straight forward and simple as possible for them. Quote
tds73 Posted May 10, 2011 Author Posted May 10, 2011 i posted the last reply before i got your reply. can i post my drawing for you to see, so i can explain it better? if so, how do i do that? how about just a pdf of drawing, that would be easiest for me, it is rather large to post drawing on here i think. Quote
ReMark Posted May 10, 2011 Posted May 10, 2011 Posting your drawing is a good idea. Someone here will take a look at it. Start a new post and click on the "Go Advanced" button in the lower right hand corner. At the next page look for the Paperclip symbol. Click on it. A file must first be uploaded before it can be attached. Watch out for file size limits. If your drawing is too large you either have to pare down the file size (erase, purge, save under a new name) or zip it first then attach it. Quote
tds73 Posted May 10, 2011 Author Posted May 10, 2011 ReMark, after reading back thru your response, i started to think maybe i was not clear on my questions/statement. in the viewport i am trying to detail, it was not drawn in plan to represent left view, i have clicked on the left view tab to rotate it there. IT IS A 3D DRAWING. I know, i am a dumb ass for leaving that info out. I am using duct designer software that draws my duct in 3d, so when i switch my view it is there. sorry for wasting so much of your time. maybe this new info makes things easier for you to answer. Quote
ReMark Posted May 10, 2011 Posted May 10, 2011 You have a 3D object displayed in your viewport. The view is of the left side. You are doing all your dimensioning in your layout and not in model space. You cannot dimension your left side view for some reason. Are all these statements true? Quote
tds73 Posted May 10, 2011 Author Posted May 10, 2011 not all of them. 3d object dispayed-yes. view is of the left side(only in the viewport i set up) . this viewport in my layout is the one i want to add text,lines and dims to. when i try to add text(for example) it lets me add it and when i click to accept it, it snaps it down to (the plan view) . if i jump back to model space, i can see it but it is at z=0. i think i need to somehow rotate ucs in the viewport so it places the text in the right x,y,z position, i just am not sure how to rotate it correctly. Quote
ReMark Posted May 10, 2011 Posted May 10, 2011 I thought you said you were dimensioning in your paper space layout. Yet, in your last post you mention seeing the text back in model space. Did you change the origin of your UCS in model space? Quote
tds73 Posted May 10, 2011 Author Posted May 10, 2011 no, i did not change origin of ucs in model space. yes, i am trying to add things in paperspace to the viewport i created, and when i do they also end up showing back on my model space. now chances are that i am not following correct autocad etiquette and probably have thing not set correctly. it is obviously hard for me to explain things correctly when posting, especially being i am pretty new to the autocad thing. maybe this will help or confuse more, let's say you are in a view port, with a 3d object shown after you click on the left view tab. for explanation purposes, say you want to show a letter next to your object and want to see it in this view. the letter would have to have the bottom at say a z value of 10, the top with a z value of 20 and the left side of letter with y value 5 and the right side y value of 0. x would just be a single value for placement/depth . does that help? Quote
ReMark Posted May 10, 2011 Posted May 10, 2011 Short answer: no. You generally have two standard choices when it comes to adding text and dimensions to a drawing. 1) Put all text and dims in model space and use Annotative Scaling. Assign an annotative scale (or scales) to your text and dimensions that will match that assigned to your paper space viewports. 2) Put all text and dims in your layout and assign values (like lengths of arrowheads and height of text) in real world values (ex. - 3/16" long arrowheads and 1/8" high text). The third "old style" and not-oft-used method-these-days is to scale your text and dimensions in model space just as you would if you were drawing "to scale" on a drafting board. So, for example, if your drawing was going to have a scale of 1/8"=1' and you wanted your plotted text to have a height of 1/8" you would give it a height of 12" in your drawing. This method leaves all objects, hatch, text, and dimensions in model space. You never use a paper space layout. I think, from your description, that you are in a layout (with viewports showing) but you are dimensioning through the viewport in model space itself. In that case I think you would have to change the orientation of your UCS and perhaps even its Origin. Quote
qball Posted May 11, 2011 Posted May 11, 2011 If your viewport is a thick border and the crosshairs stop at the border, you are working in Modelspace. If the viewport border is thin and the crosshairs extend to the edges of the screen you are in Layout (or Paperspace) Also check on the bottom taskbar, towards the right it either says PAPER or MODEL Quote
tds73 Posted May 12, 2011 Author Posted May 12, 2011 well, i got back to the drawing and went to the viewport, i don't know how or why, but the ucs is now rotated correctly and text displays the way i wanted it. chances are that my fat fingers hit something before and threw it out of whack. all is well for now. i appreciate the replies and help from you all. thanks. Quote
rkent Posted May 12, 2011 Posted May 12, 2011 While in your left view, UCS, 3, osnap to lower left corner, then lower right corner, then upper left corner. Quote
