calculate the number of rows and columns in the array !!
hii !!!
is there any way to calculate the number of rows and column of an array ????
thank you ^^
Your question is very vague, give some more info about waht you are trying to 'array'
Could the OP be interested in finding out the number of rows and columns of an existing array? Maybe he got a drawing from someone else with a very large array of columns, or trees, or floor tiles, etc.
Are you referring to the new array entities in ACAD2012?
Select/highlight one row, look in the properties pane to see how many objects are selected. Repeat for column. This assumes a block was used. Otherwise you would need to divide the property pane object number display by the number of objects in one single element.
Use Select or any random command that allows for multiple selections.
eg.
Command:
SELECT
Select objects: Specify opposite corner: 6 found
Assuming all the arrayed objects were on one layer, freeze all other layers, window the objects then click on Properties. At the top there should be a count.
thank you
yes i have an array in my drawing and i want to calculate the number of column and rows with autolisp so that i can loop in it ?! how can i do that
Loop in it? You want the lisp routine to repeat right?
None of the suggestions above meet your needs? This must be done with a lisp routine?
yes ReMark exactly i want to repeat an instruction:
(while (number of column) do something
Maybe !!! :unsure:
(setq ss (ssget ))
(repeat (sslength ss)
