ggodwin Posted May 11, 2011 Posted May 11, 2011 For some strange reason I can not print and dimension lines with an angle reference. I get the error "Cannot find or create the font AerialMT". However, I have this font on my machine. Triple checked and installed it again. any ideas? Quote
qball Posted May 11, 2011 Posted May 11, 2011 It is in your Autocad fonts? I ask because when you say "my machine" that might mean it's just installed in your Windows Fonts. Quote
SLW210 Posted May 11, 2011 Posted May 11, 2011 See if this helps... 1. Go to Plot Dialog> Choose your PDF plotter 2. Click on Properties 3. A Plotter Configuration Dialog opens up. 4. Click on Custom Properties under the Device and document Settngs tab 5. Select "Capture all " for Font Handling in DWG to PDF Properties dialog Quote
SLW210 Posted May 11, 2011 Posted May 11, 2011 _PLOT on the command line or File>Plot or CTRL+P Quote
SLW210 Posted January 26, 2012 Posted January 26, 2012 You are welcome! Glad to see you at CADTutor, mrgenediep!! Quote
MaverickPL47 Posted May 21, 2012 Posted May 21, 2012 I have just made an account to say how much I love you man! One love and big ups! Quote
McEKA Posted July 20, 2013 Posted July 20, 2013 See if this helps... 1. Go to Plot Dialog> Choose your PDF plotter 2. Click on Properties 3. A Plotter Configuration Dialog opens up. 4. Click on Custom Properties under the Device and document Settngs tab 5. Select "Capture all " for Font Handling in DWG to PDF Properties dialog Sure this works fine! I didnt know it until i faced it. Quote
