Piping behaviours
Is there anyway to specify pipe preferences?. I mean for example I'll connect 25mm Pipe to 25 pipe then I want it to use Tee, but if its 25-40 then normal takeoff. How can I specify this?.
Thanks in advance
I've tried going into PIPEPREFDEF and adding a "size range" but that never seemed to function properly. I just swap the "Branch Fitting" under the Routing Options in the Properties palette when I create a pipe run. It would be nice for the takeoff or tee would dynamically change with the varying range of pipe sizes but I don't believe it's possible, though I've been wrong before so might want to keep digging in.
I have also searched but never seen such a thing or a way. It shouldnt be so difficult but still there is nothing to specify for it. I guess the only option try to write a lisp. maybe it could work.
I don't think LISP controls the MEP stuff. I would guess it is .NET since the Swamp.org guys only talk about it when they program for the verticals.
I'm very new about lisp stuff I just know the name and using it havent started to write it on my own but willing to learn. So Why do the lisp or vba doesnt work for mep ?what is the difference between lisp and .net?
I wrote it here cause I thought there may be an option in mep without need to write a lisp or such a thing.
