organize a list from smallest to largest number
hiiii!!
how I can loop through a list and compare the numbers written on my list to organize them from smallest to largest??
"this is my list ( 25164.4 25164.4 21853.4 21708.6 25678.9 . 12875.3 )"
thank youuu
hiiii!!
thank youuu
^^ Not sure what the stand-alone decimal is doing as part of your list ^^
Here's an example:
(vl-load-com)
(setq myList (list 25164.4 25164.4 21853.4 21708.6 25678.9 12875.3))
(setq myNewList (vl-sort myList '<))
Example output:
(12875.3 21708.6 21853.4 25164.4 25164.4 25678.9)
thank youuu soo much you saved my life :D:P
You're welcome.
is this applicable on coordinates can i organize them ??? for example i have a list of coordinates like ( (28627.0 8902.0 ) (22425.0 12201.1) (28627.0 15080.1) (25736.0 12201.1)
(22425.0 15080.1 ) (22425.0 8902.0 ) (28627.0 15080.1 ) (25316.0 8902.0 )
(defun SortByX ( lst )
 (vl-sort lst '(lambda ( a b ) (< (car a) (car b))))
(defun SortByY ( lst )
 (vl-sort lst '(lambda ( a b ) (< (cadr a) (cadr b))))
(defun SortByZ ( lst )
 (vl-sort lst '(lambda ( a b ) (< (caddr a) (caddr b))))
yes you mean i have to specify (sort by x or y ) cant' i orginize them like the nearest one from the origine of coordinate ???
Lee why not...
(defun SortByN ( n lst )
 (vl-sort lst '(lambda ( a b ) (< (nth n a) (nth n b))))
Base 0 index
You can sort them using any predicate function that returns non-nil for a desired sorting result:
(defun SortByMagnitude ( lst )
 (vl-sort lst '(lambda ( a b ) (< (distance '(0. 0. 0.) a) (distance '(0. 0. 0.) b))))
Of course, the origin could be replaced by any point.
thank youuu so much pBe and lee mac you saved me twice :thumbsup:
But the main thing: do you understand the methodology?
yes i do i just started learning autolisp ... 1 month ago actually
can you help me a little bit more
when i organize my list (sort by y :
((25736.0 8902.08) (28627.0 8902.08) (22425.0 8902.08) (25316.0 8902.08)
(28627.0 11781.1) (25736.0 11781.1) (25316.0 11781.1) (22425.0 11781.1)
(25736.0 12201.1) (28627.0 12201.1) (22425.0 12201.1) (25316.0 12201.1)
(28627.0 15080.1) (25736.0 15080.1) (25316.0 15080.1) (22425.0 15080.1))
i want to add all the coordinate white the same y in a list so that my list would be like this
(((25736.0 8902.08) (28627.0 8902.08) (22425.0 8902.08) (25316.0 8902.08))
((28627.0 11781.1) (25736.0 11781.1) (25316.0 11781.1) (22425.0 11781.1))
((25736.0 12201.1) (28627.0 12201.1) (22425.0 12201.1) (25316.0 12201.1))
((28627.0 15080.1) (25736.0 15080.1) (25316.0 15080.1) (22425.0 15080.1)))
thank you
Not great coding :oops:
(defun test ( l / sub )
 (defun sub ( l )
   (if l
     (cons
       (cons (car l)
         (vl-remove-if-not
           (function
             (lambda ( x ) (equal (cadar l) (cadr x)))
           (cdr l)
       (sub
         (vl-remove-if
           (function
           (cdr l)
 (vl-sort (sub l) '(lambda ( a b ) (< (cadar a) (cadar b))))
thank you so much it worked i called the function leeMac (l / sub) lol :P
This is a more generic format:
(defun test ( l )
 (vl-sort
   (LM:GroupByFoo l
     (lambda ( a b ) (equal (cadr a) (cadr b)))
(defun LM:GroupByFoo ( lst foo )
 (if lst
   (cons
     (cons (car lst)
       (vl-remove-if-not '(lambda ( x ) (foo (car lst) x)) (cdr lst))
     (LM:GroupByFoo (vl-remove-if '(lambda ( x ) (foo (car lst) x)) (cdr lst)) foo)
_$ (test '((1 2) (3 2) (5 2) (2 4) (3 5) (5 3) (2 3) (6 3) (9 4) (2 4) (7 5) (2 5)))
 ((1 2) (3 2) (5 2))
 ((5 3) (2 3) (6 3))
 ((2 4) (9 4) (2 4))
 ((3 5) (7 5) (2 5))
