Record macro in simulation
Hello everyone. I have faced such a problem. I am doing a research and have couple of hundreds of assemblies. so I figured out that using macro to change what I need would be the easiest way.
the problem is that "record macro" doesn't work in simulation study. solidworks help says that I need to check references to solidworks simulation. this is not a problem to set it if I create marco manualy.
but is there a way to set reference permanent so that "record macro" would record what I do in study with forces and restraints, not only record selection of faces.
thanks in advance.
