afrazawan Posted May 16, 2011 Posted May 16, 2011 when im using auto numbring or inclosed text commond not working error is comoing Command: tcircle Unknown command "TCIRCLE". Press F1 for help. and: Command: tcount Unknown command "TCOUNT". Press F1 for help. pls help me why Quote
ReMark Posted May 16, 2011 Posted May 16, 2011 What happens if you invoke the command by typing .TCOUNT? Quote
afrazawan Posted May 16, 2011 Author Posted May 16, 2011 Command: tcircle Unknown command "TCIRCLE". Press F1 for help. Quote
ReMark Posted May 16, 2011 Posted May 16, 2011 What happens if you invoke the command by typing .TCIRCLE? Notice the ? Quote
afrazawan Posted May 16, 2011 Author Posted May 16, 2011 im asking u above this massege is comming on comd line wht is this Quote
ReMark Posted May 16, 2011 Posted May 16, 2011 What is this? It probably means that Express Tools is not loaded or the commands you are trying to use have been undefined. Did you try what I suggested previously or not? Quote
afrazawan Posted May 17, 2011 Author Posted May 17, 2011 Tcount Tcircle works 2012 CIV3d Express loaded ! wht is this pls tel me fully how can Quote
ReMark Posted May 17, 2011 Posted May 17, 2011 Do you think you could find the time to answer the questions I've asked? Here's another one. Is Express Tools loaded or not? Quote
afrazawan Posted May 17, 2011 Author Posted May 17, 2011 wahy not ur getting me Express Tools loaded when i was installing my CAD ok Quote
ReMark Posted May 17, 2011 Posted May 17, 2011 Did you try using a period before the command like this: .TCOUNT ? Is the Express Tools folder listed in the Support File Search Path? Quote
rkent Posted May 17, 2011 Posted May 17, 2011 At the command line type EXPRESSTOOLS, enter. If you installed the express tools then this will load them. If it says unknown command then you don't have them installed. Also run EXPRESSMENU, again at the command line. Quote
