i want to make Earth Work cross section pls helpme how can ?
? I had a look at the file and I see 3 complete road cross sections more or less.
Are you saying you want to replicate the general format of those for a new road design given you have the existing natural surface levels and the proposed finished surface levels? You would have to manually do it AutoCad. Writing a lisp is barely even feasible (and a fairly signifigant job) in this case given the possibilities for the templates (i.e. gutter profile etc) that could be applied. There are already plenty of programs that can do this and there is little point in trying to reinvent the wheel so to speak.
You should look into programs such as AutoCad Civil 3D (which can do it), Carson CivilCad or any other survey/civil design software package.
brother i need help i give u example i want to prepare same road cross section for cut and fill Qty. so kindly reffer me how cani make this good and easy way my requirement show in attached drawing so pls help me which software i can use for this pls
AutoCad Civil 3D. http://usa.autodesk.com/civil-3d/
You will need to define/create a surface (using your natural surface levels). You will then need to create the alignment for the road. Then you apply a template to the road combined with your design surface (your finished surface levels). Then you can generate you longsections and cross sections (including cut and fill volumes) automatically from your alignment.
ok thnaks i ll try it thnsk but if u send me one example or sample file in civel 3d i do'nt know civel 3D ok dear
