here how to give multiple value?i want give multiple values((setvar "plinewid" 1)..so it should ask the value means its easy to give.
(defun c:test ()
(setvar "cmdecho" 1)
(command "pline" pause)
What you mean by multiple values ? when you can change it every time you want .
It can be set as you draw your LWPolyline.
eg.
Command: P
PLINE
Specify start point:
Current line-width is 0.00
Specify next point or [Arc/Halfwidth/Length/Undo/Width]: W
Specify starting width <0.00>: 1
Specify ending width <1.00>: 2
Specify next point or [Arc/Close/Halfwidth/Length/Undo/Width]: W
Specify starting width <2.00>:
Specify ending width <2.00>: 1
(defun c:PLW () (c:PolylineWidth))
(defun c:PolylineWidth  ( / *error* width oldCmdecho oldPlinewid)
 (princ "\rPOLYLINE WIDTH ")
 (defun *error*  (msg)
   (cond ((not msg))                                                   ; Normal exit
         ((member msg '("Function cancelled" "quit / exit abort")))    ; <esc> or (quit)
         ((princ (strcat "\n** Error: " msg " ** "))))                 ; Fatal error, display it
   (and oldPlinewid (setvar 'plinewid oldPlinewid))
   (and oldCmdecho (setvar 'cmdecho oldCmdecho))
   (princ))
 (if (setq width (getreal "\Enter polyline width: "))
     (and (setq oldCmdecho (getvar 'cmdecho)) (setvar 'cmdecho 0))
     (and (setq oldPlinewid (getvar 'plinewid)) (setvar 'plinewid width))
     (command "._pline")
     (while (= 1 (logand 1 (getvar 'cmdactive)))
       (princ "\nSpecify next point: ")
       (command pause))
     (and (setvar 'plinewid oldPlinewid) (setvar 'cmdecho oldCmdecho)))
   (prompt "\n** Invalid entry ** "))
 (princ))
Edit -
MUCH simpler example (inspired by Alan's reminder):
(defun c:PolylineWidth ( / width)
 (if (setq width (getreal "\nEnter polyline width: "))
   (command "._pline" pause "_w" width ""))
 (princ))
