cadman6735 Posted May 17, 2011 Posted May 17, 2011 I have a property set that I need to replace with one from my template file. It has the same name, it has just changed format. I can copy and paste via Style Manager but I want to automate this process. I have change one of my tags to data set and it imports from my template file but only if the original has been purged out first. How can I automate the purge. Thanks Quote
SLW210 Posted May 18, 2011 Posted May 18, 2011 Is this question related to Revit or vanilla AutoCAD? Quote
tzframpton Posted May 18, 2011 Posted May 18, 2011 I have a property set that I need to replace with one from my template file. It has the same name, it has just changed format. I can copy and paste via Style Manager but I want to automate this process. I have change one of my tags to data set and it imports from my template file but only if the original has been purged out first. How can I automate the purge. Thanks I don't know that you can automate a purge from the Style Manager without customization. Can you simply update the Template file so you don't have to update new drawings? Quote
