vnanhvu Posted May 18, 2011 Posted May 18, 2011 I HAVE 3 LINES. DISTANCE LINE 1 TO 2: 1000, DISTANCE LINE 2 TO 3 : 1000. I measure the distance between two Lines 1 & 2. when i want to modify dim for know distance between two lines 1 & 3, i use command EXTEND for dim to Line 3. If have distance between two lines 1 & 3, i want between two lines 1 & 2, how do i ? can you create a lisp for both ? Thanks! Quote
Tharwat Posted May 18, 2011 Posted May 18, 2011 I couldn't solve the puzzle . Would you please be explain it a little bit more ? Quote
Tharwat Posted May 18, 2011 Posted May 18, 2011 I am waiting for the Op to post the image .Not a video Quote
alanjt Posted May 18, 2011 Posted May 18, 2011 I am waiting for the Op to post the image .Not a video He did............... Quote
vnanhvu Posted May 18, 2011 Author Posted May 18, 2011 This?[ATTACH]27667[/ATTACH] YES! AND I WANT TO MODIFY FOR 2 3 & 4 DIM SAME TIME ! Quote
Tharwat Posted May 18, 2011 Posted May 18, 2011 Trim : Trim the first left dim and Hold Shift & click would do the extend the right dim to left . That's is ... easy . Quote
eldon Posted May 18, 2011 Posted May 18, 2011 Is Lisp really necessary? What about the command Trim for the OP's first case, and just dragging the dimension for the second case? Quote
vnanhvu Posted May 18, 2011 Author Posted May 18, 2011 trim : Trim the first left dim and hold shift & click would do the extend the right dim to left . That's is ... Easy . no way create lisp for dim and extend same time !!!! Quote
BlackBox Posted May 18, 2011 Posted May 18, 2011 no way create lisp for dim and extend same time !!!! I don't know if you are meaning to do this, or not, but this keeps happening... Your punctuation conveys that you are impatient, and very demanding. Members here volunteer their time/knowledge, and while we are happy to help, but we are not here to do your work for you. In the future, good, clear explanations of your situation, and a polite request would go a long way to help you. I'd also suggest that you stop asking for code, until you have some code to post. Quote
