Hey,
Just updating the our .cuix to accomodate our needs in 2012.
Does anyone rememeber the 'Window' drop down menu in 2008? It would let you cycle between the drawings you have open.
Have they taken this away? Fed up of using Alt+TAB to navigate between. I cant find that window under any .cuix file.
Has anyone got a .cuix file that i can do a partial load on or something? :?
Really, really cannot figure this one out. :glare:
Cheers,
Nice, Mostly.
I can't say that I remember exactly what you are referring too, but it sounds like something that has been replaces with the Quick View Drawings. You access it by the two-window-button at the right-hand bottom side of AutoCAD. [ATTACH]27685[/ATTACH]functions.
If you have menubar set to 1, you should be able to see the pulldowns. From there, if 'Window' isn't loaded, just load it through the cui editor. On a side note, I prefer to use a drawing tab controller like: http://www.caelink.com/drawing_tabs.htm
Nice responses.
I like this drawing Tab manager, its compatible with 2012 then?
Nice responses.
No clue. Read and see.
HAHA! They know how to hide things in 2012 :)
"Window" is one of the tabs you get when you click View on the menu bar now.
