hii
i have a drawing with 4 lines of points (each line of points with the same Y) . i have the coordinate of the points of each line in a list and all the lists in a list .
so now i want to calculate the disatnce between points of each list knowing that the number of points in lines may change and may not be equal as follows :
so i've created a lisp that can measure the distance but the only problem is that i can calculate the distance only if the lines have the same number of points.
plzz help me ans again sorry my english is bad
  • Replies 22
  • yajis_narif
    9
  • Lee Mac
    4
  • Ahankhah
    4
  • BlackBox
    3
hii
iso i've created a lisp .....
where is it? :)
(defun LM:GroupByFoo ( lst foo )
 (if lst
   (cons
     (cons (car lst)
       (vl-remove-if-not '(lambda ( x ) (foo (cadr lst) x)) (cdr lst))
     (LM:GroupByFoo (vl-remove-if '(lambda ( x ) (foo (car lst) x)) (cdr lst)) foo)
(defun c: test (all /)
(setq lall(length all))
(setq f -1)
(setq sorty (list))
       (while ( < (setq f (1+ f)) lall)
(setq allc (vl-sort
   (LM:GroupByFoo (nth f all)
    (lambda ( a b ) (equal (cadr a) (cadr b)))
 '(lambda ( a b ) (< (cadar a) (cadar b)))
(setq sorty (append sorty (list allc)))
(setq ls (length sorty))
(setq lallc(length allc))
(setq n -1)
(setq sortall(list))
(while ( <(setq n (1+ n)) ls)
(setq m -1)
(setq sortx (list))
(while ( < (setq m (1+ m)) lallc)
(setq xx0 (vl-sort (nth m (nth n sorty))
(function (lambda (e1 e2)
( < (car e1) (car e2)) ) ) ))
(setq sortx (append sortx (list xx0)))
(setq sortall(append sortall (list sortx)))
(setq Ldie(length sortall))
(setq di1 (nth 0 sortall))
(setq l1 (length (nth 0 sortall)))
(setq ty -1)
(setq lleny (list))
(while (< (setq ty (1+ ty)) l1)
(setq lleny (append lleny (list (length (nth ty di1)))))
(princ lleny)
(setq diste (list))
(setq dislist (list))
(setq t -1)
(while ( <(setq t (1+ t)) l1)
(setq r -1)
(setq q 0)
(setq diste (list))
(while (and (< (setq r(1+ r)) 4)( < (setq q (+ 1 q)) 4))
(setq di (distance (nth r (nth t (nth 0 sortall))) (nth q (nth t (nth 0 sortall)))))
(setq diste (append diste ( list di)))
(setq dislist(append dislist (list diste)))
thanks
1- In your code one closing paranthesis is needed at the very end of file.
2- It is forbidden in AutoLISP to assign a name to a function or variable with spaces, so c: test is wrong.
3- A command defined by AutoLISP can not have any arguement, your command: test has: (defun c: test (all /) ...
I am checking the code.
i just gives you a part of the code and sorry for the c: it's a mistake my bad :lol:
thank you
I believe what Ahankah is trying to say, is that in order to supply an argument to your function you might instead use:
(defun test (all / )
 ;; <-- Your code here
Example syntax: (test all)
Renderman, you are right. English isn't my native language, I live in Iran, but you live Somewhere between Civil 3D and Maya, which means your language isn't Persian.
Ahankhah, I mean no offense to you, my friend. :)
I simply tried to provide an example to your correct statement, as when I began programming LISP, I would not have understood fully. For me, sometimes 'seeing' an example helps me to understand.
I assure you, your English is far superior to my Persian. :thumbsup:
Renderman, I just wanted to confess that I know my English isn't so good.
I respect you as one of the active members of CADTutor. I learn much in this forum and thank you and all other friends for this.
hello anyone can help me plzzz :lol:
You still looking for a help .:)
What's the issue buddy .
thanks tharwat
You want to calculate the distance from the list or from the distance between points ?
yes i want to calculate the distance between points in every line
If your point list is in the format:
 (<Point1> <Point2> ... <PointN>)
then perhaps:
(defun test ( mainlist )
 (mapcar
   (function
     (lambda ( sublist )
       (mapcar 'distance sublist (cdr sublist))
   mainlist
yes exactly my list is in that format and i want to calculate the distance between ( and ) ,( and )...... and )
thank you lee Mac it worked thanks for your help actually i was stuck in it for 3 days
