Michaels Posted May 22, 2011 Posted May 22, 2011 Hello everyone . I have a problem with my Express Tools and it brings a message at the start of cad showing that one of Lisp and fas files is not loaded . the message is ... Unable to load acetauto.lsp/fas type argument uncorrect:String nil. How can I reload the express tools folder completely with a lisp routine ? Many thanks Quote
Ohnoto Posted May 22, 2011 Posted May 22, 2011 You can use this to reload the Express Tools: Just having that one line in your startup suite will run ensure that it is re-loaded with every new drawing. (command "expresstools") If you want to do it by command and not load up everytime: (defun c:loadexp () (command "expresstools") ) Quote
Cad64 Posted May 22, 2011 Posted May 22, 2011 If the acetauto.lsp/fas file is missing, or corrupted, a lisp routine isn't going to do you any good. Insert your installation disk and run a Repair. Quote
BIGAL Posted May 23, 2011 Posted May 23, 2011 make sure your workspaces are set to save changes when you do the menuload bit else it will not work next time you open , also check your desktop icon and see what profile your starting with no much good saving express to one profile then starting in another. Quote
