blackeagle1245 Posted May 23, 2011 Posted May 23, 2011 (edited) Is there any way to convert mep drawings to revit?. I have 3d architectural and static plans in revit but I work with mep. How can I organize the relation between them?. What should I do?. If I open the drawing in mep can I work with it properly?. Thanks in advance Edited May 23, 2011 by blackeagle1245 Quote
blackeagle1245 Posted May 23, 2011 Author Posted May 23, 2011 I searched in the forum to convert mep drawings to revit I tried IFC, and convertingto3dsolids methods but not exactly as in the mep. Am I doing something wrong or those are normal things happening while converting? Quote
tzframpton Posted May 24, 2011 Posted May 24, 2011 You can't really do a seamless conversion. All you can do is export/import as IFC solids at very best. Quote
