Using Lee's ObjectDBX. How can I turn on/off layers on the xref? If it is possible... I need to turn on/off layers on our electrical plot sheets which is around 100 drawings. We use model space for our plot sheet and everything is xref in.
(vl-load-com)
[color=green];;<-- Open dbxDoc[/color]
(vlax-for oLayer (vla-get-layers dbxDoc)
 (if (vl-string-search "|" (vla-get-name oLayer))
   (vl-put-layeron oLayer :vlax-true)) [color=green];<-- Change to :vlax-false to turn off[/color]
[edit] I just re-read your post, and saw you inquired about on/off, and not freeze/thaw. Code corrected [/edit]
I'm not sure of his construct, but I'm sure he gives you the document to work with, so you could use an example like the following:
((lambda (doc)
  (vlax-for layer (vla-get-layers doc)
    (if (wcmatch (vla-get-name layer) "*|*")
      (vla-put-layeron layer :vlax-false)
 (vla-get-activedocument (vlax-get-acad-object))
Oops, didn't realize I was late to the ball.
I'm not sure of his construct, but I'm sure he gives you the document to work with ...
Absolutely right :)
@ LISP2LEARN Supply the ODBX subfunction with the lambda function from Alan's example and it should work.
For reference, here is the code being referred to:
http://lee-mac.com/odbxbase.html
