tennis4you Posted May 26, 2011 Posted May 26, 2011 I initially told AutoCAD to stack all of the fractions but I think I have since changed my mind. Where is that setting that I can turn it off in my template file so all new files will not stack fractions? I assume that setting will disable it for text and dimensions? Thanks! Quote
tmld Posted May 26, 2011 Posted May 26, 2011 Open the dimension style manager >modify >primary units (tab): linear dims: pick the choice you want from the pull down list. Quote
nestly Posted May 26, 2011 Posted May 26, 2011 Double-click the Stacked Text, highlight the stacked text in the Mtext editor, and choose "Stack Properties" from the right click menu. Quote
Mohawk Posted February 11, 2014 Posted February 11, 2014 There is not a system variable. It is stored in the registry under the MText node (HKCU). You change it if you had accidentally specified "Do not ask"..... Initiate the MTEXT command and make a boundary window for text anywhere, type a fraction, after it autostacks, highlight just the stacked fraction and right click it, select Stack Properties which is right below Unstack in the right click menu, once the properties come up, select the autostack button and there you can specify which behavior you prefer. Quote
RobDraw Posted February 11, 2014 Posted February 11, 2014 From the department of redundancy department. Quote
tzframpton Posted February 11, 2014 Posted February 11, 2014 From the department of redundancy department.Haha, that gave me a good laugh Rob. Quote
RobDraw Posted February 11, 2014 Posted February 11, 2014 Yeah, sorry, Mohawk, I couldn't resist. Quote
