Mostly Nice Posted May 26, 2011 Posted May 26, 2011 Still having troubles with 2012 The CUI will load lisp files but wont load my express or custom CADmep+ Tabs? Even though i get a message 'Load Successfull' They're shown under my menuload tool also, just will not display? I am at my witts end :ouch: Quote
BlackBox Posted May 26, 2011 Posted May 26, 2011 Instead of looking on the Transfer tab, look at the Customize tab. Confirm that the desired tabs show up correctly listed beneath the Tabs node (in the right pane of Customize tab), when your Workspace is selected (under the Workspace node in the left pane of Customize tab). If the desired tabs do not show up, then hit the Customize workspace button, and add them. Save your CUIx, hit Apply, then OK. If the desired tabs do show up, consider exiting the CUI Editor, and reapply your workspace. Seldom have I needed to change the ribbon's display mode (meaning toggle it off, then back on). After all of that, if the desired tabs still do not show, and they do show up in the Ribbon node under the workspace (on the right), then remove them from the workspace, and re-add them again. Lastly, I'm not sure how you start ACAD, and apply your workspace, but we have users that have so many menus, toolbars, tabs, etc. included as part of their workspace, that we load a script from the application icon's target path (using the /b switch) which force-loads our workspace at startup, as ACAD will only remember a certain number of menus, etc.. Hope this helps! Quote
