aleair Posted May 27, 2011 Posted May 27, 2011 Hi all, I have a block-reference with attribute-references. One of these references is a calculated field that gives the area of a polyline. This is its calculation expression: %%).Area \f "%lu2">% where 2129748024 is the ID of the linked polyline. I'd like to get the expression above in order to extract the object id number (2129748024). My aim is to get the id number and use it to insert a new attribute into the block that will have a calculated field corresponding to the length of the same polyline. I posted this issue on www.vbaexpress.com without solutions yet. Thanks in advance. Quote
fixo Posted May 27, 2011 Posted May 27, 2011 This code is is kinda dirty and tricky you have to vanish it (sorry for the bad formatting) <CommandMethod("foo")> _ Public Sub GetFieldFromAttribute() Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument Dim db As Database = doc.Database Dim ed As Editor = doc.Editor Try Dim tab As String = Autodesk.AutoCAD.ApplicationServices.Application.GetSystemVariable("ctab").ToString Dim blockname As String = ed.GetString(vbLf & "Enter blockname: ").StringResult Dim opts As PromptSelectionOptions = New PromptSelectionOptions opts.SingleOnly = True opts.MessageForRemoval = vbLf & "Select block only" opts.MessageForAdding = vbLf & "Select single block" Dim filt As SelectionFilter = New SelectionFilter({New TypedValue(0, "insert"), New TypedValue(2, blockname), New TypedValue(410, tab)}) Dim psr As PromptSelectionResult = ed.GetSelection(opts, filt) If psr.Status <> PromptStatus.OK Then Exit Sub If psr.Value.Count <> 1 Then Exit Sub Dim id As ObjectId = psr.Value.GetObjectIds(0) If id.IsNull Then Exit Sub Using tr As Transaction = db.TransactionManager.StartTransaction() Dim obj As DBObject = tr.GetObject(psr.Value.GetObjectIds(0), OpenMode.ForRead) If TypeOf obj Is BlockReference Then Dim bref As BlockReference = CType(tr.GetObject(id, OpenMode.ForRead), BlockReference) Dim attcoll As AttributeCollection = bref.AttributeCollection Dim att As AttributeReference For Each aid As ObjectId In attcoll Dim aobj As DBObject = tr.GetObject(aid, OpenMode.ForRead) att = TryCast(DirectCast(aobj, AttributeReference), AttributeReference) If att Is Nothing Then Exit Sub If att.Tag.Equals("LENGTH", StringComparison.CurrentCultureIgnoreCase) Then If att.HasFields Then Dim fld As Field = tr.GetObject(att.GetField(), OpenMode.ForRead) Dim code As String = fld.GetFieldCode Dim pos1 As Int32 = code.IndexOf("_ObjId") Dim pos2 As Integer = code.IndexOf(">%") Dim leng1 As Integer = "_ObjId".Length Dim leng2 As Integer = ">%".Length Dim idstr As String = code.Substring(pos1 + leng1 + 1, pos2 - (pos1 + leng1) - 1) MsgBox("ID from field code: " & idstr) Dim objId As ObjectId = New ObjectId(New IntPtr(Convert.ToInt32(idstr))) Dim fieldchild As DBObject = tr.GetObject(objId, OpenMode.ForRead) If TypeOf fieldchild Is Polyline Then Dim poly As Polyline = DirectCast(fieldchild, Polyline) MsgBox("Compare:" & vbLf & "Return from attribute: " & att.TextString & vbLf & "Return from Polyline: " & poly.Area.ToString) End If Exit For End If End If Next End If End Using Catch ex As Autodesk.AutoCAD.Runtime.Exception ed.WriteMessage(ex.Message + vbLf + ex.StackTrace) End Try End Sub Quote
