kalai Posted May 28, 2011 Posted May 28, 2011 i have to get the coordinates of common (outer) tangents of two circles. c1= '(0 0) c2='(0 15) r1 =12.5 r2=5 ;c1 and c2 centers ;r1 and r2 radius pls help me. Quote
Ahankhah Posted May 28, 2011 Posted May 28, 2011 (defun C:Go () (vl-load-com) (setvar 'Osmode 512) (while (not (setq 1st (entsel "Select first circle: ")))) (while (not (setq 2nd (entsel "Select second circle: ")))) (setq 1st (osnap (last 1st) "_Nea")) (setq 2nd (osnap (last 2nd) "_Nea")) (command "_.LINE" "_Tan" 1st "_Tan" 2nd "") (setq line (entget (entlast))) (princ (strcat "\nCoords:\t\t" (vl-princ-to-string (cdr (assoc 10 line))) "\t" (vl-princ-to-string (cdr (assoc 11 line))) ) ) (entdel (entlast)) ) Quote
Lee Mac Posted May 28, 2011 Posted May 28, 2011 How about using some geometry... (similar to my post here). (defun LM:2CircleTangents ( c1 r1 c2 r2 / d1 d2 tan ang ) (if (< (abs (setq d1 (- r1 r2))) (setq d2 (distance c1 c2))) (progn (setq tan (atan (sqrt (- (* d2 d2) (* d1 d1))) d1) ang (angle c1 c2) ) (list (list (polar c1 (+ ang tan) r1) (polar c1 (- ang tan) r1)) (list (polar c2 (+ ang tan) r2) (polar c2 (- ang tan) r2)) ) ) ) ) Test function: (defun c:test ( / cir1 cir2 ) (if (and (setq cir1 (car (entsel "\nSelect First Circle: "))) (eq "CIRCLE" (cdr (assoc 0 (setq cir1 (entget cir1))))) (setq cir2 (car (entsel "\nSelect Second Circle: "))) (eq "CIRCLE" (cdr (assoc 0 (setq cir2 (entget cir2))))) ) (apply 'mapcar (cons '(lambda ( a b ) (entmakex (list (cons 0 "LINE") (cons 10 a) (cons 11 b)))) (LM:2CircleTangents (cdr (assoc 10 cir1)) (cdr (assoc 40 cir1)) (cdr (assoc 10 cir2)) (cdr (assoc 40 cir2)) ) ) ) ) (princ) ) Quote
Lee Mac Posted May 28, 2011 Posted May 28, 2011 In the past I extended this idea and used a grRead construct (not practical, but fun to use/write): The code for the above is attached and will work in all UCS/Views and has no dependence on Visual LISP. This was the final product: Lee 2CircleDynTangents.lsp Quote
