tennis4you Posted May 29, 2011 Posted May 29, 2011 Is there a way to select things on an angle? The default selection tool is a rectangular shape, I need something linear that I can draw. Like draw a line through several elements and everything that line touches it selects. Thanks! Quote
tzframpton Posted May 30, 2011 Posted May 30, 2011 Yep. After you initiate the command (eg. Move, Copy, Mirror, etc), before selecting anything, type F to use the Fencing selection option. **EDIT** In fact, when you type "?" at the command line after initiating a command, it provides extra selection tools. The Fencing option might note be exactly what you're after, so try all the selection options. See below: Command: MOVE Select objects: ? Window/Last/Crossing/BOX/ALL/Fence/WPolygon/CPolygon/Group/Add/Remove/Multiple/P revious/Undo/AUto/SIngle/SUbobject/Object Quote
