sprinkler block
I am using Autocad MEP2009. The problem I have is inserting a block of asprinkler head into my drawing. I have found the sprinkler head in the piping - equipment -mechacical equipment - fire protection - dry sprinkler head. Could anyone advise me how I get the sprinkler block to beable to insert in my drawing
Think I may have entered this post into the wrong forum if any one could help. I am using Autocad MEP2009. The problem I have is inserting a block of asprinkler head into my drawing. I have found the sprinkler head in the piping - equipment -mechacical equipment - fire protection - dry sprinkler head. Could anyone advise me how I get the sprinkler block to be able to insert in my drawing
It inserts on a face, I believe. In which case, you need to use a ceiling plan with the ceilings visible. You can also use a floor slab and set an offset for the desired height.
Thanks for the reply I have set a ceiling into the drawing and gone into mechcanical equipment and opened the fire protection dialog box to the part where the sprinkler is but there doesnt seem to be anywhere in the dialog box to insert the sprinkler head into the drawing dont know if you could help with this.
Thanks
Chris
Now that I'm not in front my Revit...I believe it's in the Home tab, Plumbing Fixtures, Fire Protection Sprinkler...
Copy the block, then paste it in the drawing, off to the side where it will not show in any views. Now copy and paste into position on the drawing.
That is the quick and dirty method.
The proper procedure would is to add the block to a tool palette. Adding the block to a tool palette. the block will always be available for use in future drawings.
We also have a specific AutoCAD MEP forum on this board for future posts that are related. ;)
Home : Plumbing & Piping : Sprinkler
That's where you select to put the component in your drawing.
It isn't plane-based, it's level-based. If you can't see it in your drawing, change your offset in your properties to a positive number.
Edit: Crap, I totally missed the fact you're on 2009...I've been giving instructions from 2012.
Wait wait wait ... are you using AutoCAD or Revit? This is the Revit forum.
If AutoCAD, this is the wrong forum and I need to delete my responses.
Thanks for the help managed to sort it I am using MEP 2009 could you let me know which is the best forum for MEP.
Thanks
I have merged your 2 threads and located them in MEP forum.
