Understanding Dynamic Blocks
I am a veteran of AutoCAD, but very new at Dynamic Blocks. I have created a simple Section Line block with Rotate, Stretch, and Flip actions, and it ALMOST works the way I need it to. The Rotate and Flip actions work fine, but the Stretch action is giving me a little trouble. If I use the Stretch action first, I have no problem, but if I rotate the block first and then stretch, the attached line will go backwards. I have tried linking the Stretch to the Rotate action, but when I do that it no longer maintains a polar stretch.
I have included the DWG that I am refering to. (sec-ln.dwg)
Help!
sec-ln.dwg
You'll have to save it down to 04 I cant open it in 06 to try it. Is this what you are looking for?
SectionCallout.dwg
Yes that works perfect!!! What was doing wrong?
Also, two quick things:
1. Is there a way to make this Dynamic Block scalable? Like to where I could click on an action and the entire block either reduce by 50% or increase by 50%?
2. Are there any good comprehensive tutorials on how to create Dynamic Blocks?
initial setting of your angle parameter was set to 90 degrees causing the undesirable output after rotation. i set it to 0 degrees.
for scaling, you can use anyone of these:
1. scale property in the properties flyout/toolbar.
2. scale parameter inside block editor,
3. visibility states with list parameter inside block editor,
4. annotative blocks.
1. start in new features workshop included in acad's help.
2. there exists a lot of db tutorials, just google it. cadalyst/cadtutor/augi may have tutorials.
3. collect samples from internet/forums. we all learn from examples.
4. autocad comes with many dynamic blocks. just type adc to open design center.
5. cadtutor forum got lots of topics about db. i think its on the general cad area. lots of talented and helpful guys here.
Thanks for the help wizman and ABuckingham!
The AutoCAD White Papers available on Autodesk's site were a pretty good way for me to learn about dynamic blocks. It's a three part set (i.e. beginner, intermediate and advanced methods).
