Solidwork help required - Simple part design
Hi,
I am new to Solidworks and am learning the basics.
I am trying to design a simple part for a saxophone case.
The main part is simply an extruded shape with filleted edges.
The problem I have is with the bell curve which extrudes from the main part top and bottom.
Is it possible to simply use a dome or similar extrusion teqnique to bulge the area specifically at the point of the bell or do I need to do a more complicated 3d drawing to achieve a cone shape on both sides.
I have tried several different methods of achieving this but have not achieved anything yet that I am satified with.
Thanks,
Ben.
I would draw the profile and the do a revolve - or revolve cut to remove the part from you base shape
  • 4 weeks later...
post a picture. The use of surfacing could be required.
