I've got a few different routines to change the justification to any
of the available justifications in Autocad. Each one is pretty verbose.
What I'm looking for is a simple routine to pick my text and have it change it to Left Center .
No options, no user input.
Select Objects
Enter
Enter
Done!
Anyone have a simple routine like that or can you point me to one?
You guys are awesome!
TIA!
Here is an old one I downloaded once...
(defun c:tj (/ j e p11 p10 f en plin p10n fn y)
   (setq j (getstring "\nLeft/Center/Middle/Right  "))
   (setq j (strcase j))
   (setq e (entget (car (entsel))))
   (setq p11 (assoc 11 e))
   (setq p10 (assoc 10 e))
   (setq f (assoc 72 e))
   (setq en e)
   (if (= (cdr f) 0) (setq plin (cons 11 (cdr p10))))
   (if (= (cdr f) 0) (setq en (subst plin p11 en)))
   (if (and (= j "L") (/= (cdr f) 0))
           (setq p10 (cons 10 (cdr p11)))
           (setq en (subst p1on p10 en))
   (IF (= J "L") (setq fn 0))
   (IF (= J "C") (setq fn 1))
   (IF (= J "M") (setq fn 4))
   (IF (= J "R") (setq fn 2))
   (setq fn (cons 72 fn))
   (setq en (subst fn f en))
   (entmod en)
Nope that's not it.
I have that one and it doesn't address the
"newer" justifications.
I think the Middle Left, etc.. use both (assoc 71 & (assoc 72
Autocad release 9 had just come out when I started CAD...
So Middle Left and such were not around back then..
I guess if I could nail down group codes are specific
to a particular justification I could modify the above code
to suit.
(defun c:tjLeft(/ ss obj)
 (vl-load-com)
 (and
   (setq ss (ssget "_+.:E:S" '((0 . "TEXT"))))
   (setq obj (vlax-ename->vla-object (ssname ss 0)))
   (vla-put-alignment obj acAlignmentLeft)
acAlignmentLeft
acAlignmentCenter
acAlignmentRight
acAlignmentAligned
acAlignmentMiddle
acAlignmentFit
acAlignmentTopLeft
acAlignmentTopCenter
acAlignmentTopRight
acAlignmentMiddleLeft
acAlignmentMiddleCenter
acAlignmentMiddleRight
acAlignmentBottomLeft
acAlignmentBottomCenter
acAlignmentBottomRight
WOW!
You are way out of my league!!
Thanks so much!!
Awesome programming knowledge!
So what is the syntax for Center Justified?
I thought it was simply replacing acAlignmentLeft
with acAlignmentCenter but that moved my text to 0,0
Thanks so much!
 (vl-load-com)
 (and
acAlignmentLeft
acAlignmentCenter
acAlignmentRight
acAlignmentAligned
acAlignmentMiddle
acAlignmentFit
acAlignmentTopLeft
acAlignmentTopRight
Use this routine to get the object properties:
(defun c:dump (/ ent obj)
 (while (setq ent (entsel "\nSelect entity to get object data: "))
   (setq obj (vlax-ename->vla-object (car ent)))
   (vlax-dump-object obj t)
   (vlax-release-object obj)
Select object:
#<VLA-OBJECT IAcadText 02ce832c>
; IAcadText: AutoCAD Text Interface
; Property values:
;   Alignment = 0
;   Application (RO) = #<VLA-OBJECT IAcadApplication 00ac8928>
;   Backward = 0
;   Color = 256
;   Document (RO) = #<VLA-OBJECT IAcadDocument 01b694bc>
;   Handle (RO) = "A367"
;   HasExtensionDictionary (RO) = 0
;   Height = 5.0
;   Hyperlinks (RO) = #<VLA-OBJECT IAcadHyperlinks 02cebb0c>
;   InsertionPoint = (1799.16 -194.612 0.0)
;   Layer = "POWER"
;   Linetype = "ByLayer"
;   LinetypeScale = 1.0
;   Lineweight = -1
;   Normal = (0.0 0.0 1.0)
;   ObjectID (RO) = 29887800
;   ObjectName (RO) = "AcDbText"
;   ObliqueAngle = 0.0
;   OwnerID (RO) = 29804560
;   PlotStyleName = "ByLayer"
;   Rotation = 0.0
;   ScaleFactor = 1.0
;   StyleName = "SIMPLEX 0"
;   TextAlignmentPoint = (0.0 0.0 0.0)
;   TextGenerationFlag = 0
;   TextString = "this is a"
;   Thickness = 0.0
;   UpsideDown = 0
;   Visible = -1
See if this is what you wanted:
(defun c:tjc(/ ss obj)
 (vl-load-com)
 (if
   (and
     (setq ipt (vla-get-InsertionPoint obj)))
     (vla-put-alignment obj acAlignmentCenter)
     (vla-put-TextAlignmentPoint obj ipt)
acAlignmentLeft
acAlignmentCenter
acAlignmentRight
acAlignmentAligned
acAlignmentMiddle
acAlignmentFit
acAlignmentTopLeft
acAlignmentTopRight
  • 7 months later...
Sorry i dont know much about programming within autoCAD. Could someone tell me how i would install this? i'm using land desktop 06
add it to your ACAD.LSP file
Copy the code making sure you get the last line of the code, sometimes that is missed.
Paste it into your text editor like NotePad.
Save it to your ACAD folder, I have a sub folder named LISP which I save to.
Use APPLOAD at the command line
Navigate to the file you just saved & load it or add to your StartUp Suite to be loaded for each DWG.
Note that load will only install the routine for the current DWG & only for this session.
Look at the lisp file for (defun
the one above has this
c: means you can run it from the command line by typing tjc
If the c: was missing like this
(defun tjc(/ ss obj)
You would need to enter (tjc) to run it.
Anyone seeing anything I left out please chime in.
HTH
Great bit of advice, just a few pointers I might add if I may...
  • When saving the file in notepad or another Text Editor, make sure that the box "Save as Type" is set to "All Files", and use the extension ".lsp" when saving.
  • Alternatively to using the Start-up Suite, you could make a call to load the LISP from your ACADDOC.lsp which loads at every drawing session.
  • More help can be found here
HTH also,
Lee 8)
Thanks Lee,
Also Note
If you want to use a file to automatically load a lisp I do not recommend using the ACAD.lsp file!
It may be over written any time you upgrade ACAD or re-install ACAD.
Use the ACADDOC.lsp like this:
First see if it exist by typing this at the command line
(findfile "acaddoc.lsp")
If it returns a path you should use your editor to add a line to it.
(load "AlansAutoLoad.lsp")
make up a file name for your system like (load "MyAutoLoad.lsp")
If the file does not exist then create one with your editor.
Add this
then save as ACADDOC.LSP making sure you save it in the ACAD search path.
Now create another file with your editor called MyAutoLoad.lsp
Add this to the file:
;;;    Lisp Routine Loader
;;;    AUTOLOAD only loads the routine when needed
;;;------  Lisp name -- Function name(s) -------  Discription  -----------------------
(AUTOLOAD "MyLispFileName" '("FunctionName")) ; comment what it does
;;  End of file
Also save it to the ACAD search path.
Now each time your open a DWG the "MyLispFileName" routine will be loaded if you enter
FunctionName at the command line.
This information should definitely be added to the FAQ at some point 8)
The article we have in there at the moment is somewhat brief...
http://www.cadtutor.net/faq/questions/53/How+do+I+automatically+load+variables%3F
