Transferring CUI menus from PC to PC
I have been working on custom CUI files for my company, and when I export the Ribbon Panel to a CUI file and import it to my co-worker's PC I get two frustrating problems.
1. The CUI file won't transfer the command names, descriptions, or macros accurately. It will get about 70% of them correct, but the others have to be manually corrected.
2. The icons I created for this custom Ribbon panel will not transfer. They also have to be manually found and re-entered. (My theory on how to fix this issue is have the icons in a central location [i.e. a network folder] and have the search path added to the support files list.)
Also, on a side note:
-What purpose or use does the "Command Display Name" property have within the custom command?
