Hi
I would like to create a cummulative list of lengths (from the start) between an open polyline vertices.
So for example if I have a pline with 5 vertices then from the first vertice to the second
vertice I would have say a length of 20 then the second to the third 12 then third to fourth 18, then fourth to fifth 25.
So my list would look like something :
x = (20,32,50,75)
I can only get as far as making a points lists! Thanks any help is sincerely appreciated!
SF
Two methods I can think of:
(defun c:test1 ( / e i m l )
 (if
   (and
     (setq e (car (entsel "\nSelect LWPline: ")))
     (eq "LWPOLYLINE" (cdr (assoc 0 (entget e))))
     (setq i 0 m (vlax-curve-getendparam e))
     (while (<= (setq i (1+ i)) m)
       (setq l (cons (- (vlax-curve-getdistatparam e i) (vlax-curve-getdistatparam e (1- i))) l))
 (reverse l)
(defun c:test2 ( / e p l )
 (if
   (and
     (eq "LWPOLYLINE" (cdr (assoc 0 (setq e (entget e)))))
     (while (setq p (assoc 10 e))
       (setq l (cons (cdr p) l) e (cdr (member p e)))
     (setq l (reverse l))
     (mapcar 'distance l (cdr l))
The second assumes only straight polyline segments.
Thanks Lee that's great
- however - sorry I forgot to say 3d polylines.
I just changed LWPOLYLINE to POLYLINE
many thanks
3D Polylines will require a change to the second method:
(defun c:test2 ( / e l )
 (if
   (and
     (setq e (car (entsel "\nSelect Polyline: ")))
     (eq "POLYLINE" (cdr (assoc 0 (entget e))))
     (while (eq "VERTEX" (cdr (assoc 0 (entget (setq e (entnext e))))))
       (setq l (cons (cdr (assoc 10 (entget e))) l))
thanks - it seems both of your methods work. The only problem is that the distances given are not cummulative.
From the start I want the list values to get larger until the last one equals that total length of the 3d - pline.
Oops! Forgot about the cumulative part - well, that simplifies things:
 (if
   (and
       (setq l (cons (vlax-curve-getdistatparam e i) l))
 (reverse l)
Or even just:
(defun c:test1 ( / e i l )
 (if
   (and
     (setq i 0)
     (while (car (setq l (cons (vlax-curve-getdistatparam e (setq i (1+ i))) l))))
 (reverse (cdr l))
Or, using the other method:
(defun c:test2 ( / e l x )
 (if
   (and
     (setq l (reverse l) x 0)
     (mapcar '(lambda ( a b ) (setq x (+ x (distance a b)))) l (cdr l))
Perfect many thanks Lee
Lee - Sorry for asking again but I wonder if you could tweak your "Test2" so that only horizontal lengths (plan lengths) are given? I have tried for a couple of hours to amend your code, but with no luck.
Do you mean 2D lengths? (i.e. Points projected to the XY-plane)
Yes I do
 (if
   (and
     (mapcar
      '(lambda ( a b )
         (setq x (+ x (distance (list (car a) (cadr a)) (list (car b) (cadr b)))))
       l (cdr l)
Yes I do
sorry about the double posting.
thanks Lee yes that works well. So that's how it's done. My attempt was not even close.
Have a read of the documentation on the distance function.
