I am a newbie to Inventor. I am trying to create a drawing from a part so I can put dimensions on it. Can someone give me some assistance?
Thanks
Go to the new tab and select standard dwg - this will open the drawing environment. Then place your base view and pull off your desired projected views. right click n create.
This will give you your views and then annotate accordingly :)
