I have a formula :
(setq Formula1 (/ (* 0.046 (expt(* LenPath 78.0)(/ 1.0 2.0))) (expt SlopePath (/ 1.0 5.0))))
with two variables "LenPath" "SlopePath"
and I have 2 lists. Each item in the list represents
"LenPath" or "SlopePath"
So for example in my first list :
((setq LenList   '(2.1 4.0 6.8 10.0  12.0 16.0))
so the each item is "LenPath"
(setq SlopeList '(5.5 7.8 9.3 12.0  15.4 17.7))
each item is "SlopePath"
The new list generated would look something like:
(setq NewList '(0.418 0.538 0.678 0.781 0.814 0.914))
This is easy to do using mapcar and lambda if there is only one variable
However I stumped if there are two lists to use on one formula at the same time
Any ideas? thanks
Do you require perhaps something like this?
(mapcar
 (function
   (lambda ( _length _slope )
     (/ (* 0.046 (expt (* _length 78.0) 0.5)) (expt _slope 0.2))
 LenList
 SlopeList
I would definitely recommend you take a look at this tutorial :)
Thanks Lee
that works well. Yes I was having a look at it previously, but I could not work out from it how to use two variables at the same time. But it is a very useful tutorial - good work.
Thanks SmallFish - I found it quite difficult to write a tutorial to cater for developers of different levels of experience, whilst keeping the tutorial short and interesting.
Do you understand now the method I used above?
Maybe this will help with mapcar + lambda :
Make a couple simple lists
 (setq l1 '(2 3 4))
 (setq l2 '(2 4 )
Basic (mapcar) call:
 Add the atoms of the lists together
 (setq nl1 (mapcar '+ l1 l2))
 '(4 7 12)
 Multpily the atoms of the lists
 (setq nl2 (mapcar '* l1 l2))
 '(4 12 32)
Make an anonymous function (lambda)
: Find the length of the hypotonuse from the length of the 2 short sides
 (setq fun (lambda (a b) (sqrt (+ (* a a) (* b b)))))
 mapcar the (lambda) function to the lists
 (setq nl3 (mapcar 'fun l1 l2))
 '(2.82843 5 8.94427)
Include a (lambda) function in the (mapcar) call
: Divide the atoms in the lists as reals
  [b][color=BLACK]([/color][/b]setq nl4 [b][color=FUCHSIA]([/color][/b]mapcar '[b][color=NAVY]([/color][/b]lambda [b][color=MAROON]([/color][/b]a b[b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]/ [b][color=GREEN]([/color][/b]float a[b][color=GREEN])[/color][/b] [b][color=GREEN]([/color][/b]float b[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] l1 l2[b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b]
 '(1.0 0.75 0.5)
HTH -David
Edited by David Bethel
Thanks Lee
I need things simple to match my mind :)
