When converting a dwg file using DWG Trueview 2011, all of my dwg files now defaults to opening using DWG Trueview 2011 instead of my version of AutoCAD 2009. How do I prevent this from happening?
Right-Click a DWG file and choose "Open with" and select "choose default program..."
You can also go into AutoCAD and open any drawing from the File > Open > nav window. This will reset the Open With parameter.
Unfortunately, this will happen again the next time you use TrueView even if you use SLW's solution.
If you check the box "Always use the selected program to open this kind of file" it should always open with that program.
You'd think that would work. Hey, it does. Cool.
