jcalla Posted June 8, 2011 Posted June 8, 2011 I know this is my second time I posted this request, but I really could use some help if possible. Lee Mac almost got me where I needed to be on my last post however I didn't quite make it. I would like a routine that would prompt me for an area in square feet of a rectangle with a know length or width. I use version R14, so I don't have the option of entering the area using the rectang command which is why I am asking about a lisp routine. Can anyone help me? JPC Quote
BIGAL Posted June 8, 2011 Posted June 8, 2011 It just first principles you need to change Lee's code where he calls the _rectang command how do you draw a rectang answer join 4 points with lines. So you have point1 the pick point just use the polar command to work out pts 2 3 4 then it becomes (command "line" pt1 pt2 pt3 pt4 "C" "") Lee uses polar in his code just put command after working out extra points all done. Quote
jcalla Posted June 8, 2011 Author Posted June 8, 2011 Bigal I'm pretty much a novice so could you possibly correct the code and post it? JPC Quote
Lee Mac Posted June 8, 2011 Posted June 8, 2011 Does the code I linked you to still not work for you? Quote
jcalla Posted June 8, 2011 Author Posted June 8, 2011 Lee Mac, The code you sent the first time works but it gives me the area in square inches. The second code you sent gives me an error and I cannot run it. I did not see any link for any other code. What I would like is code that gives me area of a rectanle in square feet. I do appreciate your help and hope you will excuse my ignorance in lisp routines. JPC Quote
Lee Mac Posted June 8, 2011 Posted June 8, 2011 To put a halt to my puzzlement could try this code again, as I cannot get it to fail... the error you report indicates that part of the code is missing (a missing ')' ). Quote
irneb Posted June 8, 2011 Posted June 8, 2011 You mean you need the cvunit function. You draw in inches, but you want to input the are in sqf. So (without looking at LM's code) say it asked for the area through a getreal like so: (setq area (getreal "Area of rectangle: ")) Then you can convert it to square inches so it works with Lee's code by doing this: (setq area (cvunit area "sq feet" "sq inch")) Quote
jcalla Posted June 8, 2011 Author Posted June 8, 2011 Lee Mac, I got the code to work, however when it prompts me for either length or width it will not accept (ie) 45' but I continue with 45 and it does complete the routine with the correct total square footage. The problem is that the dimensions that I need are not accurate. I need to know the remaining dimension after I input either the length or width. It will not accept input with a foot symbol. JPC Quote
Lee Mac Posted June 8, 2011 Posted June 8, 2011 You will need to input feet and decimal inches. Quote
jcalla Posted June 8, 2011 Author Posted June 8, 2011 So what would 45 feet input look like? JPC Quote
jcalla Posted June 8, 2011 Author Posted June 8, 2011 OK, it works when I input 45 in width only, not length. Bottom line is it works! Thanks Lee Mac for sticking with me. JPC Quote
Lee Mac Posted June 8, 2011 Posted June 8, 2011 OK, it works when I input 45 in width only, not length. Bottom line is it works! Thanks Lee Mac for sticking with me. What goes wrong with the length option? Everything works for me - there isn't too much that can go wrong, its quite simple code. Quote
Lee Mac Posted June 8, 2011 Posted June 8, 2011 Ok, I changed my LUNITS setting to see if I could emulate your problems and I believe I know what the problem is. Are you entering your area in Sq.Ft or Sq.In? EDIT: Just re-read your first post, SQFT I see. Quote
Lee Mac Posted June 8, 2011 Posted June 8, 2011 Try this: (defun c:arec ( / an ar p1 x ) (if (and (setq p1 (getpoint "\nSpecify first corner point: ")) (progn (initget 6) (setq ar (getreal "\nSpecify Area for Rectangle [in SQFT]: ")) ) (progn (initget "Length Width") (setq an (getkword "\nCalculate rectangle dimensions based on [Length/Width] <Length>: ")) (if (eq "Width" an) (setq x (getdist "\nSpecify rectangle width: " p1)) (setq x (getdist "\nSpecify rectangle length: "p1)) ) ) ) (command "_.rectang" "_non" p1 "_non" (polar (polar p1 (if (eq "Width" an) 0. (/ pi 2.)) x) (if (eq "Width" an) (/ pi 2.) 0.) (/ (* ar 144.) x) ) ) ) (princ) ) Quote
alanjt Posted June 8, 2011 Posted June 8, 2011 So what would 45 feet input look like?JPC 45 ........ A nice little laugh. Quote
