Hello,
When I plot a E size template the margins all around are to huge. It is set to extents. Does anyone know how to correct this?
Thanks :cry:
check your plot scale, thats the one thing I can think of off the top of my head with out knowing more information about your template and the settings your plotting with.
Also check your Plot Dialog box, Printer/Plotter, Properties, which brings you to Plotter Configuration Editor, and Modify Standard Paper Sizes as shown
Thank you to the both of you. I will give it a try.
Thanks :D
Is it possible that the plan you are trying to plot is D size instead of E?
