Right now, i'm exchanging DWG files with an Archicad user for modifications and would like to ask if this exchange can cause, for example, a wall of a certain dimension to appear bigger/smaller inside the other software.
Since both softwares use calculations to draw instead of vectors, i would say no, bu i would just like to ask members here, to be on the safe side.
so long as the drawing units are set the same for both (and I don't mean dimensioning), I can't see how there can be a problem
You're not asking if the transition between the two could throw just one wall out are you?
