luiscarneirorm Posted November 23, 2011 Share Posted November 23, 2011 I had found this function, but the result is not what I want. the result is this: after_explode_linexp.dxf and the result I want is the following: after_explode.dxf Quote Link to comment Share on other sites More sharing options...
eldon Posted November 23, 2011 Share Posted November 23, 2011 You might do better with making a block and using measure (with the block option). One of your files first posted (post #19) had a linetype with a shape embedded in it, and unfortunately you did not include the shape file, so I cannot see what you are wanting. Quote Link to comment Share on other sites More sharing options...
VVA Posted October 25, 2013 Share Posted October 25, 2013 (edited) I modified the code to properly exploded complex line types with text. Published http://forum.dwg.ru/showthread.php?p=1171787#post1171787 test.dwg linexpVVA.lsp Edited October 25, 2013 by VVA Quote Link to comment Share on other sites More sharing options...
VVA Posted October 25, 2013 Share Posted October 25, 2013 There was an error in logic. Download the file again Quote Link to comment Share on other sites More sharing options...
VVA Posted October 25, 2013 Share Posted October 25, 2013 (edited) Linexp + Torient linexpVVATorient.LSP Edited October 25, 2013 by VVA Quote Link to comment Share on other sites More sharing options...
