luiscarneirorm Posted November 23, 2011 Posted November 23, 2011 I had found this function, but the result is not what I want. the result is this: after_explode_linexp.dxf and the result I want is the following: after_explode.dxf Quote
eldon Posted November 23, 2011 Posted November 23, 2011 You might do better with making a block and using measure (with the block option). One of your files first posted (post #19) had a linetype with a shape embedded in it, and unfortunately you did not include the shape file, so I cannot see what you are wanting. Quote
VVA Posted October 25, 2013 Posted October 25, 2013 (edited) I modified the code to properly exploded complex line types with text. Published http://forum.dwg.ru/showthread.php?p=1171787#post1171787 test.dwg linexpVVA.lsp Edited October 25, 2013 by VVA Quote
VVA Posted October 25, 2013 Posted October 25, 2013 There was an error in logic. Download the file again Quote
VVA Posted October 25, 2013 Posted October 25, 2013 (edited) Linexp + Torient linexpVVATorient.LSP Edited October 25, 2013 by VVA Quote
